Salta al contenuto principale
Toshiba Satellite R15-S829 Keyboard Replacement
Mike Strother
Mike Strother e 2 altri collaboratori
Ultimo aggiornamento il December 20, 2016
5 minuti
Moderato
Introduzione
Vai al passo 1
If you need to replace your keyboard on your own, here is an easy process on how to complete this task. All you need is a a new keyboard and a Phillips screwdriver. Be careful while replacing so you don't break anything internally. Now you are ready to get started.
Cosa ti serve
Strumenti
Mostra di più…
  1. Toshiba Satellite R15-S829 Keyboard Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Keyboard Replacement: passo 2, immagine 1 di 3 Toshiba Satellite R15-S829 Keyboard Replacement: passo 2, immagine 2 di 3 Toshiba Satellite R15-S829 Keyboard Replacement: passo 2, immagine 3 di 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: passo 3, immagine 1 di 2 Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: passo 3, immagine 2 di 2
    • First, begin by removing the plastic cover that is located at the top of the keyboard. This can be pried off or just removed by hand by grabbing the plastic piece by the indent on either side and lifting up.
    • Be careful to avoid breaking the plastic.
  4. Toshiba Satellite R15-S829 Keyboard Replacement: passo 4, immagine 1 di 1
    • Locate the two screws on each side.
  5. Toshiba Satellite R15-S829 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite R15-S829 Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the two screws with a phillips head screwdriver. Be careful not to lose the screws.
  6. Toshiba Satellite R15-S829 Keyboard Replacement: passo 6, immagine 1 di 2 Toshiba Satellite R15-S829 Keyboard Replacement: passo 6, immagine 2 di 2
    • Lift the keyboard up to reveal the power plug.
  7. Toshiba Satellite R15-S829 Keyboard Replacement: passo 7, immagine 1 di 2 Toshiba Satellite R15-S829 Keyboard Replacement: passo 7, immagine 2 di 2
    • Disconnect the keyboard from the laptop by unplugging the power ribbon.
Conclusione
UMass Dartmouth, Team 5-8, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 211
