Toshiba Satellite P55t-A5116 Power Jack Replacement
Introduzione
Vai al passo 1Use this guide to remove the Toshiba Satellite P55t-A5116 Power Jack.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Close laptop and turn it upside down
Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
Using the #PH0 screw head, remove 2 (5.7 mm) screws.
Remove metal plate.
Using the #PH0 screw head remove 1 (5.7mm) screw and 1 (4.15mm) screw.
Altre 2 persone hanno completato questa guida.
