Salta al contenuto principale
Toshiba Satellite P55t-A5116 Keyboard Replacement
Brittany Castillo
Brittany Castillo e 4 altri collaboratori
Ultimo aggiornamento il October 1, 2023
40 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
Use this guide to remove the Toshiba Satellite P55t-A5116 Keyboard.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
Panoramica Video
  1. Toshiba Satellite P55t-A5116 Keyboard Replacement, Back Casing: passo 1, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement, Back Casing: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 2, immagine 2 di 2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 3, immagine 1 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 3, immagine 2 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 3, immagine 3 di 3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
    Great write-up of process, BUT VERY IMPORTANT step to insert after Step 3: With the back off, you will have access to the wide ribbon cable for the keyboard.  See the 2nd and 3rd photos in Step 17 below.  Before doing anything else, flip up the ribbon clamp and remove the ribbon.  Inspect the underside (electrical contact side) of the cable and blow out the connector.  Carefully fully reinstall ribbon cable, but before clamping top back down, pull cable out about the width of a hair.  Then push clamp down.  This will allow tiny pins to contact a fresh spot on the exposed runs.  Then test.  This 100% fixed multiple problems with my keyboard without doing anything else (after buying a new keyboard, now just a spare…)  and saved a TON of time and trouble.  I think some people replace the keyboard and think this is what fixed it, but doing the above would have worked.  I suspect after a few years some galvanic corrosion develops that affects the tiny connections.  This makes new connections which work perfectly.
    Steve Chamberlin - Replica
  4. Toshiba Satellite P55t-A5116 Keyboard Replacement, Battery: passo 4, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement, Battery: passo 4, immagine 2 di 2
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 5, immagine 1 di 1
    • Gently remove battery from the laptop.
  6. Toshiba Satellite P55t-A5116 Keyboard Replacement, Power Jack: passo 6, immagine 1 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement, Power Jack: passo 6, immagine 2 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement, Power Jack: passo 6, immagine 3 di 3
    • Using the #PH0 screw head, remove 2 (5.7 mm) screws.
    • Remove metal plate.
    • Using the #PH0 screw head remove 1 (5.7mm) screw and 1 (4.15mm) screw.
  7. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 7, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 7, immagine 2 di 2
    • Use the plastic opening tool to push the left hinge up.
  8. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 8, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 8, immagine 2 di 2
    • Gently pull up the power jack. Follow the cord until you reach the connector.
    • Unplug the 4 pin connector and remove from laptop
  9. Toshiba Satellite P55t-A5116 Keyboard Replacement, Fan & CPU Cooler: passo 9, immagine 1 di 1
    • Using a PH0 screwdriver, remove 2 (5.7mm) screws.
    • Using a PH0 screwdriver, remove 4 (3.68mm) screws.
  10. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 10, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 10, immagine 2 di 2
    • Unplug the 3 pin connector
    • Remove fan.
  11. Toshiba Satellite P55t-A5116 Keyboard Replacement, Keyboard: passo 11, immagine 1 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement, Keyboard: passo 11, immagine 2 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement, Keyboard: passo 11, immagine 3 di 3
    • Pull out the latches on either side.
    • The RAM should pop up.
    • Remove the RAM.
    • Repeat for the other side.
  12. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 12, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 12, immagine 2 di 2
    • Remove the DVD drive by pulling it sideways out of the laptop
  13. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 13, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 13, immagine 2 di 2
    • Using the PH0 screw head, remove 2 (4.23mm) screws.
    • Slide the hard drive out.
  14. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 14, immagine 1 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 14, immagine 2 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 14, immagine 3 di 3
    • Use a plastic opening tool to gently lift the black ribbon tab and unplug the ribbon cable.
    • Remove the ribbon.
    • Lightly pull up the USB Port from the metal supports and take out of the laptop.
  15. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 15, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 15, immagine 2 di 2
    • Remove LAN port/ ethernet port. Lift up the ethernet port.
    • Unplug the 8 pin connector.
  16. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 16, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 16, immagine 2 di 2
    • Using the PH0 screw head, remove 1 (3.8mm) screw.
    • Separate the wireless adapter chip from the motherboard.
  17. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 17, immagine 1 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 17, immagine 2 di 3 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 17, immagine 3 di 3
    • Using a plastic opening tool, lift up the black ribbon tab and the smaller orange tab which are connected to the keyboard underneath.
    • Unplug the ribbons.
  18. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 18, immagine 1 di 1
    • Using the PH0 screw head, remove 2 (5.7mm) screws.
    • Using the PH0 screw head, remove 1 (4.2mm) screw.
  19. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 19, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 19, immagine 2 di 2
    • Using a plastic opening tool, remove the CP Tab that was plugged into the touchpad.
  20. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 20, immagine 1 di 1
    • Lift up the mother board and gently flip it over to sit upside down next to the laptop.
  21. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 21, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 21, immagine 2 di 2
    • Using the #J000 screw head, remove 20 (1.67mm) small screws.
    • Using the #J000 screw head, remove 4 (2.44mm) wide flathead screws.
    • Using the #J000 screw head, remove 1 (4.1mm) screw.
    • Gently lift up the metal frame from the laptop.
  22. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 22, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 22, immagine 2 di 2
    • Using the #J000 screw head, remove 4 small (1.67 mm) screws.
  23. Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 23, immagine 1 di 2 Toshiba Satellite P55t-A5116 Keyboard Replacement: passo 23, immagine 2 di 2
    • Gently lift up the keyboard out of the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
2 Commenti
This is by far the most informative instructions I have ever come upon. Not only does it explain the keyboard removal (which was my issue), but also explains the removal of pretty much every component that might need to be replaced excluding the screen. Thumbs up! I will definitely refer all my friends all colleagues to iFixit. Again Thumbs up!
Steven L Koontz - Replica
Make certain you view the comment at Step 3, it’s hidden unless you click on it. May save you time…
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,989
