Salta al contenuto principale
Toshiba Satellite P205D-S8804 Screen Replacement
Caroline Camp
Caroline Camp e 5 altri collaboratori
Ultimo aggiornamento il January 21, 2025
20 - 45 minuti
Moderato
Pallini!
Testo Confuso
Necessarie Più Immagini
Introduzione Migliore
Introduzione
Vai al passo 1
This guide will show how to remove the screen on the Toshiba Satellite.
Cosa ti serve
Strumenti
  1. Toshiba Satellite P205D-S8804 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • With the screen on a flat surface, remove the screws in each corner of the screen. There will be 4 in total.
    • Note: The screws for the screen may be hidden under rubber pad at the top of the screen so they will have to be removed.
  2. Toshiba Satellite P205D-S8804 Screen Replacement: passo 2, immagine 1 di 1
    • Using a metal spudger wedge open the front and back cover of the screen.
    • Take care to not damage the camera in the process.
  3. Toshiba Satellite P205D-S8804 Screen Replacement: passo 3, immagine 1 di 2 Toshiba Satellite P205D-S8804 Screen Replacement: passo 3, immagine 2 di 2
    • After the front cover is removed remove the two screws at the very bottom of the screen.
    • This will give you access to the screws running along the side of the screen.
  4. Toshiba Satellite P205D-S8804 Screen Replacement: passo 4, immagine 1 di 1
    • Remove the four screws on the each side of the screen. There will be eight in total.
    • We recommend starting from the bottom and working upward.
  5. Toshiba Satellite P205D-S8804 Screen Replacement: passo 5, immagine 1 di 1
    • Lay the screen flat on the keyboard so they the back panel can be accessed.
    • Remove all the tape on the video cable that connects the screen to the computer.
  6. Toshiba Satellite P205D-S8804 Screen Replacement: passo 6, immagine 1 di 1
    • Remove the video cable from the screen.
    • After the video cable is removed the screen is free and can be removed from the computer.
Conclusione
Caroline Camp
Membro da: 01/30/17
1 Reputazione
3 Guide realizzate
Baylor, Team 3-2, Whitney Spring 2017 Membro di Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 113
