Salta al contenuto principale
Toshiba Satellite P205D-S8804 Keyboard Replacement
Caroline Camp
Caroline Camp e 4 altri collaboratori
Ultimo aggiornamento il March 31, 2019
5 - 6 minuti
Moderato
Introduzione
Vai al passo 1
This is a guide to replace a malfunctioning keyboard. This guide will teach you how to unscrew your keyboard and remove the ribbon cable to allow you to replace the keyboard.
Cosa ti serve
Strumenti
  1. Toshiba Satellite P205D-S8804 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 2, immagine 1 di 1
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 3, immagine 1 di 1
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
  4. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 4, immagine 1 di 1
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
  5. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 5, immagine 2 di 2
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
  6. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 6, immagine 1 di 1
    • Once the ribbon is released the keyboard can be removed .
Conclusione
Caroline Camp
Membro da: 01/30/17
1 Reputazione
3 Guide realizzate
Baylor, Team 3-2, Whitney Spring 2017 Membro di Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
4 Membri
4 Guide realizzate
Un commento
rename tool with a standard link for easier accessibility
Andy Feng - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 226
