Salta al contenuto principale
Toshiba Satellite M55-S135 Screen Replacement
Matthew Trinh
Matthew Trinh e 9 altri collaboratori
Ultimo aggiornamento il January 21, 2025
15 minuti
Difficile
Necessarie Più Immagini
Introduzione Migliore
Introduzione
Vai al passo 1
This guide will provide a walk-through on how to remove the screen in your Toshiba Satellite.
Cosa ti serve
Strumenti
Mostra di più…
  1. Toshiba Satellite M55-S135 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
    • Slide the unlock switch in the top left-hand corner to the left/unlock position.
  2. Toshiba Satellite M55-S135 Screen Replacement: passo 2, immagine 1 di 1
    • Hold the switch in upper right-hand corner to the right.
    • With the switch held open, pull the battery straight away from the laptop.
  3. Toshiba Satellite M55-S135 Screen Replacement, Screen: passo 3, immagine 1 di 2 Toshiba Satellite M55-S135 Screen Replacement, Screen: passo 3, immagine 2 di 2
    • Use the plastic opening tool to remove the four small rubber pop-out squares from the corners of your screen.
    • The laptop displayed in the picture does not have these plastic squares.
  4. Toshiba Satellite M55-S135 Screen Replacement: passo 4, immagine 1 di 2 Toshiba Satellite M55-S135 Screen Replacement: passo 4, immagine 2 di 2
    • Use the Phillips 00 screwdriver to unscrew the four 6.72mm screws from the corners of the screen.
    • The screws will be located underneath the previously removed black squares.
  5. Toshiba Satellite M55-S135 Screen Replacement: passo 5, immagine 1 di 1
    • Use the plastic opening tool to pop off the black plastic casing that surrounds the screen.
  6. Toshiba Satellite M55-S135 Screen Replacement: passo 6, immagine 1 di 2 Toshiba Satellite M55-S135 Screen Replacement: passo 6, immagine 2 di 2
    • Use the Phillips 00 screwdriver to remove the two 6.72mm screws at the bottom left and right of the screen.
  7. Toshiba Satellite M55-S135 Screen Replacement: passo 7, immagine 1 di 2 Toshiba Satellite M55-S135 Screen Replacement: passo 7, immagine 2 di 2
    • Turn the laptop 90 degrees clockwise.
    • Use the Phillips 00 screwdriver to remove the six 3.78mm screws from both sides of the screen.
    • Hold on to the screen while removing the screws.
  8. Toshiba Satellite M55-S135 Screen Replacement: passo 8, immagine 1 di 1
    • Fold the screen down so that the back of the screen is visible.
    • Remove the yellow wiring connected to the top of the back of the screen by pulling it out and then up.
  9. Toshiba Satellite M55-S135 Screen Replacement: passo 9, immagine 1 di 1
    • Use the Phillips 00 screwdriver to remove the 5.54mm screw connecting the green panel to the laptop frame.
  10. Toshiba Satellite M55-S135 Screen Replacement: passo 10, immagine 1 di 1
    • Pull out the green panel and disconnect the black cable from the belly of the green panel.
    • The screen should be fully disconnected from laptop at this point.
Conclusione
Cal Poly, Team 7-11, Maness Winter 2013 Membro di Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,140
