Salta al contenuto principale
Toshiba Satellite M55-S135 Optical Drive Replacement
Yuheng Huang
Yuheng Huang e 11 altri collaboratori
Ultimo aggiornamento il August 22, 2016
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
This guide will illustrate how to replace the optical drive in your Toshiba Satellite.
Cosa ti serve
Strumenti
  1. Toshiba Satellite M55-S135 Optical Drive Replacement, RAM: passo 1, immagine 1 di 1
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 Optical Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite M55-S135 Optical Drive Replacement: passo 3, immagine 2 di 2
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
  4. Toshiba Satellite M55-S135 Optical Drive Replacement, Optical Drive: passo 4, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the 6.50mm screw holding the gray metal bracket in place.
  5. Toshiba Satellite M55-S135 Optical Drive Replacement: passo 5, immagine 1 di 1
    • Turn the laptop 180 degrees then tilt the near side up.
    • Push the back side of the optical drive out of the laptop using the plastic opening tool.
  6. Toshiba Satellite M55-S135 Optical Drive Replacement: passo 6, immagine 1 di 1
    • Pull the optical drive out of the laptop using your fingers.
  7. Toshiba Satellite M55-S135 Optical Drive Replacement: passo 7, immagine 1 di 1
    • Using the Phillips 00 screwdriver, unscrew the two 2.50mm screws that connect the metal bracket to the optical drive.
    • Remove the bracket from optical drive.
Conclusione
Yuheng Huang
Membro da: 01/28/13
13 Reputazione
1 Guida realizzata
Cal Poly, Team 7-11, Maness Winter 2013 Membro di Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 655
