Toshiba Satellite M55-S135 Battery Replacement
Introduzione
Vai al passo 1This guide will be referred to for other steps because disconnecting the power to your computer is crucial to do before working on it. Two spring-loaded switches lock the Toshiba Satellite M55-S135 battery into place.
Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
Slide the unlock switch in the top left-hand corner to the left/unlock position.
