Salta al contenuto principale
Toshiba Satellite L875D-S7210 Battery Replacement
Ian M Sloop
Ian M Sloop e un altro collaboratore
Ultimo aggiornamento il December 14, 2018
1 - 2 minuti
Molto facile
Introduzione
Vai al passo 1
Can’t turn on your laptop? Does it only turn on when it is plugged into the charger? Does your computer suddenly die, or has a much shorter battery life than it used to? If any of these are the case, it is likely that there is an issue with your battery, and it will need to be replaced. This guide will provide step-by-step guidance with pictures depicting the removal and replacement of the battery.
  1. Toshiba Satellite L875D-S7210 Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L875D-S7210 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Flip over the computer and locate the battery.
  2. Toshiba Satellite L875D-S7210 Battery Replacement: passo 2, immagine 1 di 3 Toshiba Satellite L875D-S7210 Battery Replacement: passo 2, immagine 2 di 3 Toshiba Satellite L875D-S7210 Battery Replacement: passo 2, immagine 3 di 3
    • Move latch one (right hand side) on the right to the unlock position.
    • While pressing latch two (left side latch) toward the left, place one or two fingers under then indent and lightly lift until the battery dislodges.
Conclusione
Ian M Sloop
Membro da: 10/20/18
667 Reputazione
4 Guide realizzate
UC Davis, Team S7-G7, Lore Fall 2018 Membro di UC Davis, Team S7-G7, Lore Fall 2018
UCD-LORE-F18S7G7
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 435
