Salta al contenuto principale
Toshiba Satellite L755D-S5150 Motherboard Replacement
Shaheedah
Shaheedah e 7 altri collaboratori
Ultimo aggiornamento il September 22, 2023
30 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
Usually when people hear that their motherboard needs to be replaced they think that it is the end for their computer. It is something that should be done with care since there are many intricate parts. It's good to have something to put your screws in, too.
Cosa ti serve
Strumenti
  1. Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Motherboard Replacement, Keyboard: passo 2, immagine 1 di 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Motherboard Replacement: passo 3, immagine 1 di 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Using the Phillips PH00 screwdriver remove the three 4mm screws from the cover for the RAM.
    • Use the Phillips PH00 to remove the one 4mm screw that holds the ODD.
    • Slide the ODD outward.
    • Removing the RAM is not necessary
    • The ODD is also commonly referred to as a CD-ROM.
  6. Toshiba Satellite L755D-S5150 Motherboard Replacement: passo 6, immagine 1 di 1
    • Use the Phillips PH00 screwdriver to remove one 4mm screw.
    • Use the Phillips PH00 screwdriver to remove the two 3mm screws from the fan.
    • The motherboard will be accessed from below the keyboard, therefore you will not need to take out the bottom of the laptop.
  7. Toshiba Satellite L755D-S5150 Motherboard Replacement: passo 7, immagine 1 di 1
    • Use the Phillips PH00 to unscrew the fifteen 4mm screws holding down the motherboard.
  8. Toshiba Satellite L755D-S5150 Motherboard Replacement: passo 8, immagine 1 di 2 Toshiba Satellite L755D-S5150 Motherboard Replacement: passo 8, immagine 2 di 2
    • Lift the motherboard and disconnect the 4 pin connector on the bottom side.
Conclusione
Altre 2 persone hanno completato questa guida.
Shaheedah
Membro da: 10/06/16
276 Reputazione
2 Guide realizzate
USF Tampa, Team 2-5, Sullivan Fall 2016 Membro di USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Membri
5 Guide realizzate
Un commento
This my laptop for now .
mouhmmad ghassan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,084
