Salta al contenuto principale
Toshiba Satellite L755D-S5150 Battery Removal
Kyler Clonts
Kyler Clonts e 4 altri collaboratori
Ultimo aggiornamento il December 28, 2016
30 secondi
Molto facile
Introduzione
Vai al passo 1
Anytime you perform "surgery" on your laptop, you always want to make sure you're not connected to power. Even though you can unplug your laptop from the wall, you should always make sure to remove the battery, too.
  1. Toshiba Satellite L755D-S5150 Battery Removal, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L755D-S5150 Battery Removal, Battery: passo 1, immagine 2 di 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
Conclusione
Altre 2 persone hanno completato questa guida.
Kyler Clonts
Membro da: 10/06/16
258 Reputazione
2 Guide realizzate
USF Tampa, Team 2-5, Sullivan Fall 2016 Membro di USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Membri
5 Guide realizzate
Un commento
I've got a trouble when I try to charge the battery, when I plug in the power supply charger at the laptop it is lit led one and three in the front panel, that is OK, but after a few seconds all leds blinking and the charge is breaking on the screen appear no battery plug in. I replaced the battery pack for a new one, but the trouble continuos……
Iván Andrade - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 244
