Toshiba Satellite L675D-S7016 RAM Replacement
Introduzione
Vai al passo 1If you find that your computer is responding slow, this guide will show you how to access and remove the RAM.
Cosa ti serve
Strumenti
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Using your fingers, spread the spring tabs holding the top stick of RAM in place.
Once the tabs are spread apart, the stick of RAM will pop up.
Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
