Salta al contenuto principale
Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement
Robby
Robby e 8 altri collaboratori
Ultimo aggiornamento il May 7, 2024
15 - 20 minuti
Difficile
Fallo a Fettine
Introduzione
Vai al passo 1
This guide will instruct you how to replace your Toshiba Satellite camera.
This will fix:
  • A broken video chat camera
  • A broken microphone
Cosa ti serve
Strumenti
  1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: passo 1, immagine 1 di 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: passo 1, immagine 2 di 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: passo 1, immagine 3 di 3
    • Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws.
    • Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
  2. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: passo 2, immagine 2 di 2
    • With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry.
    • Do not attempt to pry apart the bottom, the LCD assembly never gets fully disassembled in this tutorial.
  3. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: passo 3, immagine 2 di 2
    • Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
  4. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: passo 4, immagine 1 di 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Carefully disconnect the camera board from the laptop. We used tweezers.
Conclusione
Robby
Membro da: 02/04/13
52 Reputazione
1 Guida realizzata
Cal Poly, Team 7-7, Maness Winter 2013 Membro di Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,648
