Salta al contenuto principale
Toshiba Satellite L55-A RAM Module Replacement
Arthur Shi
Arthur Shi e un altro collaboratore
Ultimo aggiornamento il August 19, 2019
3 - 5 minuti
Facile
Introduzione
Vai al passo 1
This guide shows how to access the Toshiba L55’s two RAM slots in order change or add RAM modules.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM cover: passo 1, immagine 1 di 1
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A RAM Module Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L55-A RAM Module Replacement: passo 2, immagine 2 di 2
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: passo 3, immagine 1 di 3 Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: passo 3, immagine 2 di 3 Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: passo 3, immagine 3 di 3
    • This step shows how to remove a RAM module.
    • Use your fingers to spread the two metal clips securing the edge of the RAM module. This should free the module and cause it to pop up slightly.
    • Pull the RAM module out of its slot and remove it.
  4. Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: passo 4, immagine 1 di 3 Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: passo 4, immagine 2 di 3 Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: passo 4, immagine 3 di 3
    • This step shows how to insert a RAM module.
    • Insert the replacement RAM at a shallow angle into the RAM slot until the gold contacts are fully socketed.
    • Use your fingers to gently press the RAM module's edges down until both metal clips snap into place.
    • If your laptop will not properly recognize the installed RAM, unseat and reseat the RAM, making sure that all modules are fully locked in place.
Conclusione
Arthur Shi
Membro da: 01/03/18
282.664 Reputazione
587 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.455 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 241
