Salta al contenuto principale
Toshiba Satellite L505D-GS6000 RAM Replacement
Adam Dellicker
Adam Dellicker e un altro collaboratore
Ultimo aggiornamento il June 5, 2018
3 - 4 minuti
Facile
Introduzione
Vai al passo 1
Use this guide to replace your RAM.
If you are experiencing memory issues or your computer struggles to run some programs, then you should use this.
The process is simple and requires only removing one screw.
Cosa ti serve
Strumenti
  1. Toshiba Satellite L505D-GS6000 RAM Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L505D-GS6000 RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 RAM Replacement: passo 2, immagine 1 di 1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 RAM Replacement, RAM: passo 3, immagine 1 di 2 Toshiba Satellite L505D-GS6000 RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Place the laptop upside down so the bottom is facing up and the side that opens is facing you.
    • In the middle of the laptop there is a panel held down by one 6 mm screw, remove that screw using a Phillips #0 screwdriver.
    • Place the screw down in a place that you will not lose it.
    • Remove the RAM cover.
  4. Toshiba Satellite L505D-GS6000 RAM Replacement: passo 4, immagine 1 di 2 Toshiba Satellite L505D-GS6000 RAM Replacement: passo 4, immagine 2 di 2
    • The unlock the RAM push out on the metal pieces touching the RAM on the bottom and top side until it clicks
    • Once you do that gently slide the ram out and place it to the side.
    • Be gentle as to not damage any of the pieces within the laptop, excessive force could break the RAM slots and require more repairs.
  5. Toshiba Satellite L505D-GS6000 RAM Replacement: passo 5, immagine 1 di 2 Toshiba Satellite L505D-GS6000 RAM Replacement: passo 5, immagine 2 di 2
    • You’ll need to do the same as the top for the bottom set of RAM, so gently push outward on the metal pieces above and below the RAM.
    • Again be gentle when following these steps as you could could cause more damage than you’re able to fix.
    • Gently slide the RAM out from the slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 428
