Toshiba Satellite L505 Laptop Fan Replacement
Introduzione
Vai al passo 1A fan can often get clogged due to dust and it may break. This guide will help you to replace your fan so that your computer won't get overheated.
Cosa ti serve
Open the laptop and locate the plastic strip just above the keyboard.
With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
Turn the laptop upside down.
Remove the screw labeled F4 using the Phillips #1 screwdriver.
Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
Unscrew all of the screws marked on the underside of the laptop.
Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
Remove the three flat screws in the port where the Optical drive is housed in.
Once the Motherboard is exposed, unscrew the screws circled in red.
Afterwards, gently unplug all the wires connected to the motherboard.
Altre 4 persone hanno completato questa guida.
