Salta al contenuto principale
Toshiba Satellite L455D-S5976 Optical Drive Replacement
NateJohnson
NateJohnson e 7 altri collaboratori
Ultimo aggiornamento il November 30, 2015
Nessuna stima
Moderato
Introduzione
Vai al passo 1
The optical drive is what reads a CD or DVD when placed in the drive. To replace it, follow the steps outlined in this guide.
Cosa ti serve
Strumenti
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Optical Drive: passo 4, immagine 1 di 1
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 5, immagine 1 di 1
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 6, immagine 1 di 1
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 7, immagine 1 di 1
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 8, immagine 1 di 1
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 9, immagine 1 di 2 Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 9, immagine 2 di 2
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 10, immagine 1 di 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 10, immagine 2 di 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 10, immagine 3 di 3
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 11, immagine 1 di 1
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 12, immagine 1 di 1
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 13, immagine 1 di 1
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 14, immagine 1 di 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 14, immagine 2 di 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 14, immagine 3 di 3
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 15, immagine 1 di 1
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 Optical Drive Replacement: passo 16, immagine 1 di 1
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
Conclusione
Altre 2 persone hanno completato questa guida.
NateJohnson
Membro da: 01/26/14
1.047 Reputazione
5 Guide realizzate
Cal Poly, Team 9-26, Maness Winter 2014 Membro di Cal Poly, Team 9-26, Maness Winter 2014
CPSU-MANESS-W14S9G26
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,182
