Toshiba Satellite L455-S5975 LCD Display Replacement
Introduzione
Vai al passo 1This guide is useful for replacing a broken LCD screen on your laptop. If you are reading this from a laptop, you are looking at an LCD screen. In this replacement guide, you will remove the old LCD panel and install a new one.
Note: Before starting any removal or installation, remember to turn off the device and to remove it from the power source.
Cosa ti serve
Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
Flip the laptop over to access the battery.
Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
Remove the following six screws located at the base of the monitor:
Three 5mm Phillip Head Screws
Two 6mm Phillip Head Screws
One 7mm Phillip Head Screw
Disconnect the long thing grey cable that is attached to the motherboard by pulling it out.
Altre 4 persone hanno completato questa guida.
