Salta al contenuto principale
Toshiba Satellite L455-S5975 Keyboard Replacement
Mike Kennedy
Mike Kennedy e 12 altri collaboratori
Ultimo aggiornamento il February 19, 2020
5 minuti
Facile
Introduzione
Vai al passo 1
This guide is useful for replacing a broken keyboard on your Toshiba Satellite L455-S5975. In this replacement guide, you will remove the old keyboard and install the new one.
Note: Before starting any removal or installation, remember to turn off the device and to remove it from the power source.
Cosa ti serve
Strumenti
  1. Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Keyboard Replacement: passo 3, immagine 1 di 1
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite L455-S5975 Keyboard Replacement: passo 4, immagine 2 di 2
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
Conclusione
Mike Kennedy
Membro da: 04/18/13
160 Reputazione
4 Guide realizzate
Cal Poly, Team 2-21, Maness Spring 2013 Membro di Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,403
