Salta al contenuto principale
Toshiba Satellite L455-S5046 Battery Replacement
Daryl Spurgeon
Daryl Spurgeon e 2 altri collaboratori
Ultimo aggiornamento il April 19, 2017
1 minuto
Molto facile
Introduzione
Vai al passo 1
In this guide we will be teaching you how to change the battery. You will need a replacement battery that was designed specifically for the Toshiba Satellite L455-S5046. No other tools are required.
Panoramica Video
  1. Toshiba Satellite L455-S5046 Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L455-S5046 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
Conclusione
You should now have a new battery placed in your computer.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 309
