Toshiba Satellite L45-S7423 Dial Up Modem Replacement
Introduzione
Vai al passo 1The dial up modem allows the user to connect to the internet through a wired connection if a wireless source is not available. This guide shows to the user how to replace the dial up modem if it is not functioning properly.
Cosa ti serve
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the two screws holding modem in place.
Two 3.6 mm Phillips screws.
