Salta al contenuto principale
Toshiba Satellite L45-S7423 Battery Replacement
Stephen Sippel
Stephen Sippel e 5 altri collaboratori
Ultimo aggiornamento il June 14, 2023
1 minuto
Molto facile
Guida Studente in Evidenza
Introduzione
Vai al passo 1
The removal of the battery is one of the easiest tasks on the Toshiba Satellite L45-S7423. With the simple slide of a switch the user can remove that battery to allow for replacement. It is strongly recommended to remove the battery before conducting repairs on the laptop.
  1. Toshiba Satellite L45-S7423 Battery Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite L45-S7423 Battery Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite L45-S7423 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Battery Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L45-S7423 Battery Replacement: passo 2, immagine 2 di 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Battery Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L45-S7423 Battery Replacement: passo 3, immagine 2 di 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
Conclusione
Cal Poly, Team 21-54, Johann Spring 2013 Membro di Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,617
