Salta al contenuto principale
Toshiba Satellite L35-S2174 RAM Replacement
Fiona Turick
Fiona Turick e 3 altri collaboratori
Ultimo aggiornamento il December 21, 2016
1 - 4 minuti
Facile
Introduzione
Vai al passo 1
Problems with your RAM can keep the computer from starting properly. Replacing your laptop's RAM can help with memory problems, or improve speed and functionality.
Cosa ti serve
  1. Toshiba Satellite L35-S2174 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 RAM Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L35-S2174 RAM Replacement: passo 2, immagine 2 di 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 RAM Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L35-S2174 RAM Replacement: passo 3, immagine 2 di 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 RAM Replacement: passo 4, immagine 1 di 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 RAM Replacement, RAM: passo 5, immagine 1 di 3 Toshiba Satellite L35-S2174 RAM Replacement, RAM: passo 5, immagine 2 di 3 Toshiba Satellite L35-S2174 RAM Replacement, RAM: passo 5, immagine 3 di 3
    • Unscrew the two circled screws with a J1 screwdriver. The screws will remain attached to the panel.
    • Lift the panel and remove it from the laptop.
  6. Toshiba Satellite L35-S2174 RAM Replacement: passo 6, immagine 1 di 3 Toshiba Satellite L35-S2174 RAM Replacement: passo 6, immagine 2 di 3 Toshiba Satellite L35-S2174 RAM Replacement: passo 6, immagine 3 di 3
    • Pull the flaps apart on either side of the RAM chip. It will pop upwards.
    • Carefully lift the RAM chip out of the computer.
Conclusione
Fiona Turick
Membro da: 10/18/16
101 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 1-4, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 333
