Salta al contenuto principale
Toshiba Satellite L305D-S5950 LCD Screen Replacement
William
William e 3 altri collaboratori
Ultimo aggiornamento il July 15, 2014
15 - 20 minuti
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
In order to replace the LCD screen on your device the keyboard and motherboard cover need to be removed.
The keyboard needs to be removed due to the cable connecting it to the motherboard interfering with the removal of the top part of the motherboard case.
The top part of the motherboard case needs to be removed due to it being in the way of the removal of the front part of the LCD case.
Cosa ti serve
Strumenti
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 3, immagine 2 di 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Keyboard: passo 5, immagine 1 di 2 Toshiba Satellite L305D-S5950 LCD Screen Replacement, Keyboard: passo 5, immagine 2 di 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 7, immagine 1 di 3 Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 7, immagine 2 di 3 Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Motherboard Cover: passo 9, immagine 1 di 2 Toshiba Satellite L305D-S5950 LCD Screen Replacement, Motherboard Cover: passo 9, immagine 2 di 2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 10, immagine 1 di 3 Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 10, immagine 2 di 3 Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 10, immagine 3 di 3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  11. Toshiba Satellite L305D-S5950 LCD Screen Replacement, LCD Screen: passo 11, immagine 1 di 3 Toshiba Satellite L305D-S5950 LCD Screen Replacement, LCD Screen: passo 11, immagine 2 di 3 Toshiba Satellite L305D-S5950 LCD Screen Replacement, LCD Screen: passo 11, immagine 3 di 3
    • Located and unscrew the four 5.25mm screws located on the four corners of the LCD screen.
    • There might be teflon pads covering them that need to be removed to see the screws.
    • Use your hands to pry off the frame around the LCD screen.
    • Remove the frame from the LCD screen.
  12. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 12, immagine 1 di 2 Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 12, immagine 2 di 2
    • Remove the four 5.25mm screws on the sides of the LCD screen (this step will be done two times, for either side of the screen).
    • Remove the 5.25mm screw shown in the second picture.
    • Laptop has been rotated 180 degrees to complete the last step.
  13. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 13, immagine 1 di 3 Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 13, immagine 2 di 3 Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 13, immagine 3 di 3
    • Unplug the wire located on the right side of the chip under the LCD screen
    • Unplug the wire located on the left side of the chip under the LCD screen. (Laptop has been rotated 180 degrees to complete this step)
    • Unplug the LCD screen from the motherboard.
  14. Toshiba Satellite L305D-S5950 LCD Screen Replacement: passo 14, immagine 1 di 1
    • Remove the LCD screen from the laptop.
Conclusione
William
Membro da: 03/26/14
889 Reputazione
7 Guide realizzate
Clemson, Team 1-2, Benson Spring 2014 Membro di Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 880
