Salta al contenuto principale
Toshiba Satellite L305D-S5900 RAM Replacement
Sing Yang Cheng
Sing Yang Cheng e 2 altri collaboratori
Ultimo aggiornamento il June 12, 2023
15 minuti
Moderato
Introduzione
Vai al passo 1
Whether you’re upgrading, replacing, or just toying around with your computer’s RAM, this guide will provide the steps to access and remove the computer’s RAM chips.
Cosa ti serve
Strumenti
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L305D-S5900 RAM Replacement: passo 2, immagine 2 di 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L305D-S5900 RAM Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L305D-S5900 RAM Replacement: passo 3, immagine 3 di 3
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
Conclusione
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 275
