Toshiba Satellite L305-S5955 Fan Replacement
Introduzione
Vai al passo 1If your cooling fan fails or your computer overheats easily, it might be time to upgrade or replace your cooling fan.
Cosa ti serve
Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
Once the battery is removed, locate and unscrew the 3.2 mm PH1000 Phillips head screws that are underneath the battery.
Flip the motherboard over and locate the fan.
Unscrew the two Phillips head PH1 4.3 mm screws connecting the fan to the motherboard and pull up on the 3 colored wires until they are detached.
Lift the fan up and slide it out from the motherboard. Now you are ready to put in your new fan.
