Salta al contenuto principale
Toshiba Satellite L15W-B1208X Hard Drive Replacement
Brian Herbster
Brian Herbster e 2 altri collaboratori
Ultimo aggiornamento il January 10, 2023
15 - 25 minuti
Moderato
Introduzione
Vai al passo 1
This guide demonstrates how to remove a Toshiba Satellite L15W-B1208X hard drive. Reasons the hard drive might need replacing include the hard drive making noise, not running as fast as you would like, or not as much storage as you would like. Before removing the hard drive make sure that it has been backed up so information stored on it is not lost.
Cosa ti serve
Strumenti
Mostra di più…
  1. Toshiba Satellite L15W-B1208X Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 2, immagine 1 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 2, immagine 2 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 3, immagine 3 di 3
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 4, immagine 1 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 4, immagine 2 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 4, immagine 3 di 3
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
  5. Toshiba Satellite L15W-B1208X Hard Drive Replacement, Sound Board: passo 5, immagine 1 di 2 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Sound Board: passo 5, immagine 2 di 2
    • Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
  6. Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 6, immagine 1 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 6, immagine 2 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using the ESD Safe Tweezers Blunt Nose gently pull on the plastic connector that attaches the speaker wiring to the soundboard to disconnect the soundboard from the laptop.
    • Gently pull the wire away from the soundboard using the ESD Safe Tweezers Blunt Nose.
  7. Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 7, immagine 1 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 7, immagine 2 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 7, immagine 3 di 3
    • Gently lift the soundboard out of the laptop.
  8. Toshiba Satellite L15W-B1208X Hard Drive Replacement, Hard Drive: passo 8, immagine 1 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Hard Drive: passo 8, immagine 2 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Hard Drive: passo 8, immagine 3 di 3
    • Pull up on the ribbon beneath the hard drive to lift the hard drive upwards.
  9. Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 9, immagine 1 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 9, immagine 2 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 9, immagine 3 di 3
    • Gently pull the hard drive towards the edge of the laptop to disconnect the hard drive from the laptop circuitry.
  10. Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 10, immagine 1 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 10, immagine 2 di 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: passo 10, immagine 3 di 3
    • Remove the hard drive from black rubber mount by pulling the corner of the rubber mount away from the hard drive.
    • Continue pulling the rubber mount away from the hard drive until all four corners have been taken off.
    • Pull the remainder of the rubber mount away from the hard drive.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 512
