Salta al contenuto principale
Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement
Joshua Swanson
Joshua Swanson e 2 altri collaboratori
Ultimo aggiornamento il January 7, 2023
10 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace a defective USB, HDMI, and audio jack circuit board in your Toshiba E45t-B4300.
Cosa ti serve
Strumenti
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Battery: passo 1, immagine 2 di 2
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: passo 2, immagine 1 di 1
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Bottom Case: passo 3, immagine 1 di 1
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: passo 4, immagine 1 di 1
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: passo 6, immagine 1 di 1
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: passo 7, immagine 1 di 3 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: passo 7, immagine 2 di 3 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: passo 7, immagine 3 di 3
    • Use the point end of the spudger to lift the clips that attach the two ribbons to the motherboard.
    • Pull out the ribbons from the motherboard.
  8. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: passo 8, immagine 1 di 2 Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: passo 8, immagine 2 di 2
    • Unscrew the 2mm screw with a Phillips #0 screwdriver.
    • Remove the circuit board.
Conclusione
USF Tampa, Team S2-G2, Sullivan Spring 2017 Membro di USF Tampa, Team S2-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G2
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 340
