Salta al contenuto principale
Toshiba Satellite E45t-A4300 Fan Replacement
Jose Marques
Jose Marques e 3 altri collaboratori
Ultimo aggiornamento il January 7, 2023
8 - 10 minuti
Moderato
Introduzione
Vai al passo 1
The fan is what keeps the laptop from overheating so that the laptop can keep running the programs and surfing the web without slowing down. If the laptop persists in being uncomfortably hot, even after air dusting the fan several times, then replacing the fan may be needed.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Toshiba Satellite E45t-A4300 Fan Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45t-A4300 Fan Replacement: passo 2, immagine 1 di 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45t-A4300 Fan Replacement, Fan: passo 3, immagine 1 di 2 Toshiba Satellite E45t-A4300 Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  4. Toshiba Satellite E45t-A4300 Fan Replacement: passo 4, immagine 1 di 1
    • Gently disconnect the fan cable from the device.
  5. Toshiba Satellite E45t-A4300 Fan Replacement: passo 5, immagine 1 di 2 Toshiba Satellite E45t-A4300 Fan Replacement: passo 5, immagine 2 di 2
    • Move the wires away from the fan’s hook.
    • Remove the fan from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Jose Marques
Membro da: 11/01/18
433 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 604
