Salta al contenuto principale
Toshiba Satellite E105-S1602 Wifi Card Replacement
Ian Washburne
Ian Washburne e 9 altri collaboratori
Ultimo aggiornamento il May 7, 2024
Nessuna stima
Moderato
Necessarie Immagini Migliori
Introduzione Migliore
Introduzione
Vai al passo 1
The WiFi card is what assists your device with connecting to the internet without an Ethernet cable. If nothing is wrong with the router that you are trying to connect with then you may need to replace your WiFi card.
Cosa ti serve
Strumenti
Mostra di più…
  1. Toshiba Satellite E105-S1602 Wifi Card Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement, Battery: passo 1, immagine 2 di 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 2, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 2, immagine 2 di 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Wifi Card Replacement, Keyboard: passo 3, immagine 1 di 3 Toshiba Satellite E105-S1602 Wifi Card Replacement, Keyboard: passo 3, immagine 2 di 3 Toshiba Satellite E105-S1602 Wifi Card Replacement, Keyboard: passo 3, immagine 3 di 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 4, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 4, immagine 2 di 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 5, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 5, immagine 2 di 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 6, immagine 1 di 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 7, immagine 1 di 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 8, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 8, immagine 2 di 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  9. Toshiba Satellite E105-S1602 Wifi Card Replacement, Front Panel: passo 9, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement, Front Panel: passo 9, immagine 2 di 2
    • Locate the four silver screws on the front panel.
    • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  10. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 10, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 10, immagine 2 di 2
    • Flip the laptop over and locate all seven screws on the bottom of the laptop.
    • Unscrew all seven Philips#00 7.70mm screws.
  11. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 11, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 11, immagine 2 di 2
    • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
    • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  12. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 12, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 12, immagine 2 di 2
    • Rotate the laptop so the back faces you.
    • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  13. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 13, immagine 1 di 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 13, immagine 2 di 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 13, immagine 3 di 3
    • Use the plastic opening tool to pry the top panel up from the base of the computer.
    • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
    • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
    • Disconnect ribbons, and slowly lift the top panel up, away from the base.
  14. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 14, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 14, immagine 2 di 2
    • Locate the ribbon cable from the motherboard.
    • Using plastic removing tools, pop the ribbon base from the motherboard.
  15. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 15, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 15, immagine 2 di 2
    • Locate the two plugs from the motherboard.
    • Using plastic opening tools, remove each plug from the motherboard.
  16. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 16, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 16, immagine 2 di 2
    • Locate the ribbon cable partially hidden under the front panel.
    • Using plastic opening tools, pop out the ribbon cable from the motherboard.
  17. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 17, immagine 1 di 1
    • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
    • Slowly lift the top panel away from the base of the computer.
    • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
  18. Toshiba Satellite E105-S1602 Wifi Card Replacement, Wifi Card: passo 18, immagine 1 di 1
    • Locate the WiFi card, which is directly beneath the disc drive.
  19. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 19, immagine 1 di 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 19, immagine 2 di 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 19, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Locate the black wire and white wire connected to the WiFi card.
    • Using a pair of tweezers remove the wires by lifting them straight up away from the board.
    • For reassembly, note that the black wire connects to the top port, and the white wire to the bottom part.
  20. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 20, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 20, immagine 2 di 2
    • Locate and remove the two Philips #00 4.85 mm screws on the left of the WiFi card.
  21. Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 21, immagine 1 di 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: passo 21, immagine 2 di 2
    • Be careful not to pull the WiFi card straight up, as you might damage components on the motherboard.
    • Grip the sides of the WiFi card and lift it up partially.
    • Gently pull the WiFi card away from the black plastic base to remove.
Conclusione
Cal Poly, Team 17-21, Forte Winter 2013 Membro di Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,894
