Salta al contenuto principale
Toshiba Satellite E105-S1602 Front Panel Replacement
Ian Washburne
Ian Washburne e 8 altri collaboratori
Ultimo aggiornamento il January 2, 2023
Nessuna stima
Facile
Necessarie Immagini Migliori
Introduzione Migliore
Introduzione
Vai al passo 1
The front panel may need to be replaced if your track pad is not working. However, this guide is very important as it can be found in nearly every other guide. Removing the front panel is how you get to most of the other parts of the device.
Cosa ti serve
Strumenti
  1. Toshiba Satellite E105-S1602 Front Panel Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 2, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 2, immagine 2 di 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Front Panel Replacement, Keyboard: passo 3, immagine 1 di 3 Toshiba Satellite E105-S1602 Front Panel Replacement, Keyboard: passo 3, immagine 2 di 3 Toshiba Satellite E105-S1602 Front Panel Replacement, Keyboard: passo 3, immagine 3 di 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 4, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 4, immagine 2 di 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 5, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 5, immagine 2 di 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 6, immagine 1 di 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 7, immagine 1 di 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 8, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 8, immagine 2 di 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  9. Toshiba Satellite E105-S1602 Front Panel Replacement, Front Panel: passo 9, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement, Front Panel: passo 9, immagine 2 di 2
    • Locate the four silver screws on the front panel.
    • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  10. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 10, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 10, immagine 2 di 2
    • Flip the laptop over and locate all seven screws on the bottom of the laptop.
    • Unscrew all seven Philips#00 7.70mm screws.
  11. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 11, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 11, immagine 2 di 2
    • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
    • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  12. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 12, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 12, immagine 2 di 2
    • Rotate the laptop so the back faces you.
    • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  13. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 13, immagine 1 di 3 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 13, immagine 2 di 3 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 13, immagine 3 di 3
    • Use the plastic opening tool to pry the top panel up from the base of the computer.
    • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
    • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
    • Disconnect ribbons, and slowly lift the top panel up, away from the base.
  14. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 14, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 14, immagine 2 di 2
    • Locate the ribbon cable from the motherboard.
    • Using plastic removing tools, pop the ribbon base from the motherboard.
  15. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 15, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 15, immagine 2 di 2
    • Locate the two plugs from the motherboard.
    • Using plastic opening tools, remove each plug from the motherboard.
  16. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 16, immagine 1 di 2 Toshiba Satellite E105-S1602 Front Panel Replacement: passo 16, immagine 2 di 2
    • Locate the ribbon cable partially hidden under the front panel.
    • Using plastic opening tools, pop out the ribbon cable from the motherboard.
  17. Toshiba Satellite E105-S1602 Front Panel Replacement: passo 17, immagine 1 di 1
    • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
    • Slowly lift the top panel away from the base of the computer.
    • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
Conclusione
Cal Poly, Team 17-21, Forte Winter 2013 Membro di Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 952
