Salta al contenuto principale
Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement
Matthew Hook
Matthew Hook e 5 altri collaboratori
Ultimo aggiornamento il May 7, 2024
25 minuti
Moderato
Introduzione
Vai al passo 1
This guide will walk you through step by step on how to replace the screen display assembly on a Toshiba Satellite CL15t-b1204x. The screen display is vulnerable to any type of physical damage, whether that be from exposure to liquids or screen crackings. It may also need to be replaced if it stops working after a long period of time. One thing to keep in mind, is that the display comes as a full assembly, and a new assembly can be ordered online.
Cosa ti serve
Strumenti
Mostra di più…
  1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 2, immagine 1 di 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 3, immagine 1 di 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 4, immagine 1 di 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 5, immagine 1 di 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 6, immagine 1 di 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: passo 7, immagine 1 di 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: passo 7, immagine 2 di 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: passo 7, immagine 3 di 3
    • Unplug the power connector by pulling back the tape and sliding the connector away using the blue opening tool.
  8. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 8, immagine 1 di 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 8, immagine 2 di 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the foam and unplug the black and white coaxial cables to the network card by pulling upward using the black tweezers.
  9. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 9, immagine 1 di 2 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 9, immagine 2 di 2
    • Remove the black webcam connector by pulling backwards with the tweezers.
  10. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 10, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove four 5.00 mm screws from both corner hinges of the display assembly.
  11. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 11, immagine 1 di 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 11, immagine 2 di 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 11, immagine 3 di 3
    • Open the laptop and remove the display assembly from the keyboard assembly.
Conclusione
Matthew Hook
Membro da: 03/25/19
439 Reputazione
4 Guide realizzate
IUPUI, Team S1-G6, Hovde Fall 2019 Membro di IUPUI, Team S1-G6, Hovde Fall 2019
IUPUI-HOVDE-F19S1G6
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 309
