Toshiba Satellite C855D-S5303 Battery Replacement
Introduzione
Vai al passo 1This guide will show you how to remove your laptops battery. This process requires no tools; just your hands! When doing this, make sure that the device is powered off and not hot from recent usage.
Lay your laptop upside down on a flat surface.
Power off your laptop and unplug the charger.
Altre 2 persone hanno completato questa guida.
Un commento
It appears likely that these batteries are NICAD type. And NiCad batteries CAN be reprogrammed to accept charge.
Is that possible with these Toshiba units?
