Salta al contenuto principale
Toshiba Satellite C855-S5115 Keyboard Replacement
Claire Fletcher
Claire Fletcher e 2 altri collaboratori
Ultimo aggiornamento il December 29, 2022
15 minuti
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
Sticking and broken keys means it might be time for a new keyboard. This guide will show you how to remove and replace you Toshiba's keyboard.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Keyboard Replacement: passo 2, immagine 1 di 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
  4. Toshiba Satellite C855-S5115 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite C855-S5115 Keyboard Replacement: passo 4, immagine 2 di 2
    • Pull out the keyboard gently and fold it backwards.
  5. Toshiba Satellite C855-S5115 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C855-S5115 Keyboard Replacement: passo 5, immagine 2 di 2
    • Pull out the connector attaching the keyboard to the main body of the laptop.
Conclusione
2 Commenti
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - Replica
Do you have to do anything with the connector before removing?
William - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,768
