Toshiba Satellite C675-S7106 RAM Replacement
Introduzione
Vai al passo 1Replacing and re-seating RAM is a common fix and upgrade done to laptops. This laptop model makes it easy - all you’ll need is a PH0-head screwdriver and a pry tool.
Cosa ti serve
Strumenti
Flip the laptop over, so that the "top" of the laptop is against your working surface.
Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
Rotate the laptop so that the battery cavity faces away from you.
Unscrew the single PH0 head screw connecting the center panel to the laptop.
Using a plastic spudger, unclip and remove the panel from the device.
