Salta al contenuto principale
Toshiba Satellite C655-S5212 LCD Screen Replacement
Barrington Edman
Barrington Edman e 3 altri collaboratori
Ultimo aggiornamento il November 30, 2023
10 - 15 minuti
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This is a guide on how to remove a LCd screen from 15" Toshiba Satellite Laptop. Model # C655-S5212
Cosa ti serve
Strumenti
  1. Toshiba Satellite C655-S5212 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Toshiba Satellite C655-S5212 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Toshiba Satellite C655-S5212 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • First remove the stickers covers the screws in the 4 corners of LCD case. Stickers are very thin and using utility knife is easiest way to remove without damaging them. After removing stickers unscrew top 2 screws then proceed to Step 2 before trying to remove bottom 2 screws.
  2. Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 2, immagine 1 di 3 Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 2, immagine 2 di 3 Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Turn laptop around to back, and undo the 2 latches in back in order to remove bottom 2 screws of LCD screen. Use your utility knife to slide into crack and push down to unlatch.
  3. Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 3, immagine 1 di 2 Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Once screws are removed, remove cover bezel from LCD very gently without breaking it, you should hear clicking noise when removing.
  4. Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 4, immagine 1 di 2 Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove 2 screws at bottom of LCD frame and also the 2 screws at top of LCD frame (not pictured). This will allow you to lay the back cover away from frame to access side easier and remove the 3 screws on each side to detach LCD screen. Do not pull LCD once unscrewed, lay down face down on keyboard for last step.
  5. Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 5, immagine 1 di 3 Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 5, immagine 2 di 3 Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 5, immagine 3 di 3
    • Before trying to remove video cable from back of LCD. First gently remove cable from adhesive holding it down to board. Then remove tape from top of cable holding connector in place. Be very gentle at these points.
  6. Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 6, immagine 1 di 3 Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 6, immagine 2 di 3 Toshiba Satellite C655-S5212 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Now gently pull tab to pull cable from slot, be careful not to pull too hard and damage pins when removing. Once removed remove board and install new one.
Conclusione
Altre 10 persone hanno completato questa guida.
2 Commenti
Aoa sir....where to buy a new lcd screen for toshiba core i3??? Plz tell me
kingkhan201189 - Replica
I usually get mine from Amazon or Ebay. On the back of LCD there is a sticker with the model number
Barrington Edman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 28
Tutti i Tempi: 8,059
