Salta al contenuto principale
Toshiba Satellite C655-S5142 RAM Replacement
Hunter Gonsalves
Hunter Gonsalves e un altro collaboratore
Ultimo aggiornamento il December 23, 2022
2 minuti
Facile
Introduzione
Vai al passo 1
If you are having issue with your RAM, this guide will walk you through replacing the parts. The only tool needed is a PH1 Philips head screwdriver.
Cosa ti serve
  1. Toshiba Satellite C655-S5142 RAM Replacement, RAM: passo 1, immagine 1 di 2 Toshiba Satellite C655-S5142 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Ensure that your laptop is turned off and the battery has been removed
    • Flip over your laptop where the battery side is closest to you.
  2. Toshiba Satellite C655-S5142 RAM Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C655-S5142 RAM Replacement: passo 2, immagine 2 di 2
    • Unscrew the singlular screw in plate with a Phillips #1 screwdriver.
    • The screw does not come all the way out of the plastic plating, instead there is a protector that keeps it in place for you even when fully unscrewed.
  3. Toshiba Satellite C655-S5142 RAM Replacement: passo 3, immagine 1 di 3 Toshiba Satellite C655-S5142 RAM Replacement: passo 3, immagine 2 di 3 Toshiba Satellite C655-S5142 RAM Replacement: passo 3, immagine 3 di 3
    • To remove the RAM sticks, put your thumbs on the metal pins and push outwards.
    • Once pushed outwards, the first RAM stick will pop up at an angle
    • After the RAM is at an angle, you can now remove that stick of RAM and repeat the process to the second stick of RAM.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 251
