Salta al contenuto principale
Toshiba Satellite C655-S5142 Hard Disk Drive Replacement
Alex Kozlowski
Alex Kozlowski e 5 altri collaboratori
Ultimo aggiornamento il January 3, 2023
3 minuti
Facile
Introduzione
Vai al passo 1
If your Toshiba C655-S51142 has slowed to a snail's pace or has completely crashed, it may be time to replace your hard drive. Follow this guide to replace the hard drive.
The hard drive is the part of the computer that stores files, applications, pictures and even the entire operating system. Signs of a failing hard drive include receiving frequent error messages, a major computer slow down or the dreaded blue screen of death. But, before you grab your screw driver, review the troubleshooting page for tips that may get you back up and running without fully replacing the hard drive.
Before you begin, make sure you backup your hard drive. Also, be sure to power off your computer and disconnect from electrical sources.
Cosa ti serve
  1. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement, Hard Disk Drive: passo 1, immagine 1 di 2 Toshiba Satellite C655-S5142 Hard Disk Drive Replacement, Hard Disk Drive: passo 1, immagine 2 di 2
    • Unplug your computer, and make sure that it is shut off before starting.
    • Flip over your laptop, making sure the hard drive is facing you.
  2. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: passo 2, immagine 2 di 2
    • Using a Phillips head screwdriver, remove the one screw holding the backplate on.
  3. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: passo 3, immagine 2 di 2
    • With a Phillips head screwdriver remove the final screw holding the hard drive in place.
  4. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: passo 4, immagine 1 di 1
    • To remove the hard drive, lift up the plastic tap attached to it and slowly pull up using your other hand as support.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 366
