Salta al contenuto principale
Toshiba Satellite C55Dt-A5306 Disc Drive Replacement
zeena qiryaqoz
zeena qiryaqoz e 3 altri collaboratori
Ultimo aggiornamento il December 15, 2022
5 - 25 minuti
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
This guide will show users how to replace the Toshiba Satellite C55Dt-A5306 disc drive.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 2, immagine 1 di 1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Back Cover: passo 3, immagine 1 di 1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 4, immagine 1 di 1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 5, immagine 1 di 1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 6, immagine 2 di 2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: passo 7, immagine 1 di 2 Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: passo 7, immagine 2 di 2
    • Slide the disc drive to the left. It should come off with ease.
Conclusione
Un commento
Change the title to say "optical drive," rather than "disc drive." I was fooled while looking for instructions on removing the hard drive.
ed_l_grey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 460
