Salta al contenuto principale
Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement
Laura Tamayo
Laura Tamayo e un altro collaboratore
Ultimo aggiornamento il December 15, 2022
15 - 30 minuti
Moderato
Introduzione
Vai al passo 1
In the case you need to replace the cooling fan and heat sink of your Toshiba Satellite C55D-C5106, this guide will show you the steps on how to perform the task.
Cosa ti serve
Strumenti
  1. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: passo 1, immagine 1 di 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: passo 1, immagine 2 di 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: passo 1, immagine 3 di 3
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 2, immagine 1 di 1
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 3, immagine 1 di 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 3, immagine 2 di 2
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
    • Use the metal spudger to remove the bottom cover of the laptop.
  4. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove the screw securing the fan.
  5. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 5, immagine 1 di 1
    • Loosen the four screws securing the heat sink using the same screwdriver.
    • These screws cannot be removed.
  6. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 6, immagine 1 di 1
    • Disconnect the fan from the motherboard by removing the white holder with the red, yellow, and black wires.
  7. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 7, immagine 1 di 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 7, immagine 2 di 2
    • Pull the fan and heat sink away from the motherboard.
Conclusione
Laura Tamayo
Membro da: 02/14/19
678 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G4, Leahy Spring 2019 Membro di USF Tampa, Team S1-G4, Leahy Spring 2019
USFT-LEAHY-S19S1G4
4 Membri
10 Guide realizzate
Un commento
My Toshiba laptop shut down exactly after 30 minutes why is the reason? Please tell me the problem & the solution.
Afetes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 382
