Toshiba Satellite C55D-B5310 Touchpad Replacement
Introduzione
Vai al passo 1If you are unable to use the touchpad of your laptop, use this guide to remove and replace the touchpad.
Cosa ti serve
Strumenti
Mostra di più…
Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
Remove the thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
