Toshiba Satellite C55D-B5206 Trackpad Replacement
Introduzione
Vai al passo 1This guide will show you how to easily remove the Track Pad from a Toshiba Satellite C55D-B5206. This is a very easy process as shown in this guide.
Cosa ti serve
Turn the laptop upside down so the battery faces upwards.
Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
Use a non-metallic object to remove the yellow polyimide tape that covers the trackpad connector.
