Salta al contenuto principale
Toshiba Satellite C55D-B5206 RAM Replacement
David Amodei
David Amodei e 4 altri collaboratori
Ultimo aggiornamento il January 25, 2024
15 - 30 minuti
Moderato
Pallini!
Introduzione Migliore
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Toshiba Satellite C55D-B5206 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • Make sure to put your screws in a safe place to make sure they do not get lost.
  2. Toshiba Satellite C55D-B5206 RAM Replacement: passo 2, immagine 1 di 1
    • Once you take the screws out, take the battery off; it should slide off easily.
  3. Toshiba Satellite C55D-B5206 RAM Replacement: passo 3, immagine 1 di 1
    • Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
  4. Toshiba Satellite C55D-B5206 RAM Replacement: passo 4, immagine 1 di 1
    • Then, carefully take off the back casing of the laptop and set it aside.
  5. Toshiba Satellite C55D-B5206 RAM Replacement: passo 5, immagine 1 di 1
    • This is where the RAM is located that you will be replacing.
  6. Toshiba Satellite C55D-B5206 RAM Replacement: passo 6, immagine 1 di 1
    • There are two clips holding the RAM in place.
    • You will need to hold both of them back to be able to safely remove the RAM.
    • Use plastic spudgers, as the metal spudgers pictured here are not ESD-safe.
  7. Toshiba Satellite C55D-B5206 RAM Replacement: passo 7, immagine 1 di 1
    • Gently remove the RAM and insert replacement.
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
This guide was done wonderfully. My critique for your group is to be more specific with the direction of how to pull/place the components of the device. Your instructions were simple, yet clear. Great work.
Dan Hartzell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 576
