Toshiba Satellite C55D-B5206 Hard Drive Replacement
Introduzione
Vai al passo 1Hard disks may crash after long periods of use. In the event your hard drive crashes, or you simply desire to upgrade to a solid state drive. Replacing the hard drive is moderately easy and requires a few simple steps.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
Turn the laptop upside down so the battery faces upwards.
Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
Altre 7 persone hanno completato questa guida.
2 Commenti
Thanks.. Really helped out..
