Salta al contenuto principale
Toshiba Satellite C55D-B5206 Hard Drive Replacement
Michelle
Michelle e 4 altri collaboratori
Ultimo aggiornamento il April 22, 2023
10 minuti
Moderato
Introduzione
Vai al passo 1
Hard disks may crash after long periods of use. In the event your hard drive crashes, or you simply desire to upgrade to a solid state drive. Replacing the hard drive is moderately easy and requires a few simple steps.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Back Casing: passo 3, immagine 1 di 1
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 5, immagine 1 di 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 5, immagine 2 di 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 5, immagine 3 di 3
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
  7. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 7, immagine 1 di 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 7, immagine 2 di 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 7, immagine 3 di 3
    • Locate the four side plugs of the blue plastic casing which secure the hard drive in place.
    • Unplug the four clips by gently pulling them upward.
  8. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 8, immagine 1 di 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 8, immagine 2 di 2
    • Gently slide the hard disk towards the right side of your laptop.
    • The hard disk drive should now be free from the black connector port.
  9. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 9, immagine 1 di 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 9, immagine 2 di 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 9, immagine 3 di 3
    • Gently lift the hard drive upward, removing it from the Toshiba device.
    • The hard disk should now be completely removed from the Toshiba Satellite C55D device.
Conclusione
Altre 7 persone hanno completato questa guida.
Michelle
Membro da: 09/17/15
175 Reputazione
1 Guida realizzata
CSU Fullerton, Team 2-5, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
4 Membri
18 Guide realizzate
2 Commenti
Thanks.. Really helped out..
SpeedyBlanco - Replica
I opened the Toshiba but the HD unit & tie downs are a little bit different. Can I send you a picture or do facetime perhaps so you can easily see?
myfinman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 30
Tutti i Tempi: 4,846
