Salta al contenuto principale
Toshiba Satellite C55D-B5206 Fan Replacement
Tayyaba
Tayyaba e 6 altri collaboratori
Ultimo aggiornamento il April 22, 2023
15 - 20 minuti
Moderato
Introduzione
Vai al passo 1
The fan of your Toshiba Satellite C55D device may malfunction at some point. If your constantly heats up shuts down, that indicates the fan has malfunctioned. This manual will provide a step-by-step guide to replace the fan,
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Toshiba Satellite C55D-B5206 Fan Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C55D-B5206 Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Fan Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55D-B5206 Fan Replacement: passo 2, immagine 2 di 2
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Fan Replacement, Back Casing: passo 3, immagine 1 di 1
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Fan Replacement: passo 4, immagine 1 di 1
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Fan Replacement: passo 5, immagine 1 di 3 Toshiba Satellite C55D-B5206 Fan Replacement: passo 5, immagine 2 di 3 Toshiba Satellite C55D-B5206 Fan Replacement: passo 5, immagine 3 di 3
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 Fan Replacement, Fan: passo 6, immagine 1 di 2 Toshiba Satellite C55D-B5206 Fan Replacement, Fan: passo 6, immagine 2 di 2
    • Remove the three 7 mm Philips head screws by turning the screws counter clockwise.
  7. Toshiba Satellite C55D-B5206 Fan Replacement: passo 7, immagine 1 di 1
    • Gently lift the copper heat sink to make the fan more accessible.
    • The copper heat sink should not detach. Do not pull on it too hard.
  8. Toshiba Satellite C55D-B5206 Fan Replacement: passo 8, immagine 1 di 2 Toshiba Satellite C55D-B5206 Fan Replacement: passo 8, immagine 2 di 2
    • Maneuver the fan's bottom left corner above the copper heat sink.
  9. Toshiba Satellite C55D-B5206 Fan Replacement: passo 9, immagine 1 di 1
    • Cautiously move the white cable cover to allow for the fan to be lifted away.
    • Do not detach the white cable cover.
  10. Toshiba Satellite C55D-B5206 Fan Replacement: passo 10, immagine 1 di 1
    • Lift the fan approximately one inch upward from back of the laptop.
    • Detach the white cable connector from the connective port.
  11. Toshiba Satellite C55D-B5206 Fan Replacement: passo 11, immagine 1 di 1
    • Once the cable port is detached, lift the fan free from the device.
Conclusione
Tayyaba
Membro da: 09/24/15
527 Reputazione
4 Guide realizzate
CSU Fullerton, Team 2-5, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 22
Tutti i Tempi: 493
