Salta al contenuto principale
Toshiba Satellite C55D-A5108 RAM Stick Replacement
Geoffrey Souza
Geoffrey Souza e un altro collaboratore
Ultimo aggiornamento il December 14, 2022
20 - 50 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show you how to remove the RAM from the Toshiba Satellite C55D-A5108 laptop. Before completing this guide please remove the battery before beginning to opening the device.
The RAM may need to be replaced if your laptop is running slow while running many programs or if you are having trouble loading into Windows.
Do not touch the golden contacts on the end of the RAM sticks as this could damage the sticks and make them useless.
Cosa ti serve
Strumenti
  1. Toshiba Satellite C55D-A5108 RAM Stick Replacement, Battery: passo 1, immagine 1 di 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 RAM Stick Replacement: passo 2, immagine 1 di 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 RAM Stick Replacement: passo 3, immagine 1 di 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 RAM Stick Replacement, RAM Stick: passo 4, immagine 1 di 1
    • Use a Phillips #0 screwdriver to unscrew the memory cover.
  5. Toshiba Satellite C55D-A5108 RAM Stick Replacement: passo 5, immagine 1 di 1
    • Carefully hold the edges of the RAM and remove the stick.
  6. Toshiba Satellite C55D-A5108 RAM Stick Replacement: passo 6, immagine 1 di 1
    • Line up the new stick of RAM with the gold contacts facing the slot and evenly push the new stick into the same slot which you removed the old stick.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 317
