Salta al contenuto principale
Toshiba Satellite C55-C5268 Hard Drive Replacement
Greg Smith
Greg Smith e 5 altri collaboratori
Ultimo aggiornamento il December 14, 2022
15 minuti
Facile
Introduzione
Vai al passo 1
The hard drive of a laptop is where all the data is stored. From your operating system to those pictures of your dogs, it's all located within this unassuming gizmo. If a hard drive fails, it can be catastrophic. Be sure to back up important data regularly!
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
Mostra di più…
  1. Toshiba Satellite C55-C5268 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55-C5268 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Hard Drive Replacement, Back Panel: passo 3, immagine 1 di 1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Hard Drive Replacement: passo 4, immagine 1 di 2 Toshiba Satellite C55-C5268 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Hard Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite C55-C5268 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Pull the two rubber stops upward to move them out of the way and free the hard drive.
  7. Toshiba Satellite C55-C5268 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Slide the hard drive to the right towards the stops. This disconnects it from the motherboard.
    • This will require some force to slide the hard drive.
  8. Toshiba Satellite C55-C5268 Hard Drive Replacement: passo 8, immagine 1 di 1
    • The hard drive can be lifted out for replacement.
Conclusione
Altre 8 persone hanno completato questa guida.
Greg Smith
Membro da: 10/24/16
347 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 4-1, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 38
Tutti i Tempi: 14,169
