Salta al contenuto principale
Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement
Jessie
Jessie e 2 altri collaboratori
Ultimo aggiornamento il December 6, 2022
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to remove the memory chip from your Toshiba Satellite C55-B5302 laptop. You will need a Phillips #0 screwdriver and a plastic opening tool. Make sure your laptop is unplugged and cool before you start. The memory chip is easy to remove and should take 10 to 15 minutes.
Cosa ti serve
Strumenti
  1. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: passo 1, immagine 2 di 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 2, immagine 2 di 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 3, immagine 1 di 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): passo 4, immagine 1 di 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): passo 4, immagine 2 di 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): passo 4, immagine 3 di 3
    • Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 5, immagine 1 di 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 5, immagine 2 di 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 5, immagine 3 di 3
    • Push down on the two clips holding the RAM chip in place.
    • Pull the RAM chip up slightly and out away from the connection to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,257
