Toshiba Satellite C55-B5200 Optical Disk Drive Replacement
Introduzione
Vai al passo 1A guide on how to replace the optical disk drive on a Toshiba Satellite C55-B5200 laptop.
Cosa ti serve
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Make sure device is turned off and unplugged
Use J0 Philips Head Screwdrivers to remove 13, 6.6 mm screws on back of device
